Re: H piston
Posted by Janicholson on September 29, 2011 at 13:58:50 from (199.17.6.77):
In Reply to: H piston posted by Jim Isler on September 29, 2011 at 13:39:01:
The piston must match the sleeve. Measure the bore pretty acurately and purchase a piston for it. If the sleeves have a ridge that you can easily feel with your thumb nail, it probably needs sleeves and pistons. An overbore (really just using thinnwer sleeves will add power and cost no more than original new parts. Jim
