Re: Need help troubleshooting 1950 H
Posted by Arossihman on September 29, 2011 at 21:39:57 from (216.70.54.200):
In Reply to: Need help troubleshooting 1950 H posted by PurdueAg on September 29, 2011 at 19:53:55:
after you resolve timing issues make sure your valves are adjusted properly....i have seen the retainer nuts for the rocker arms back off. also if your valves did stick pull the valve cover and make darn sure your push rods are not bent.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
