Re: H piston
Posted by mkirsch on September 30, 2011 at 06:49:24 from (64.80.110.74):
In Reply to: H piston posted by Jim Isler on September 29, 2011 at 13:39:01:
You know, it depends on what you currently have...
That means you've gotta measure your existing bore. The engine could have been rebuilt with the overbore pistons at any time in the last 72 years.
Pistons come in many sizes. Most people when they rebuild an H put in overbore pistons and sleeves for more power.
