The rocking must be pretty radical. If you look at the fan while rocking the tractor, and it moves (even an inch) the starter is not jammed. If it does not move the starter may be jammed. To unjam it it is necessary to loosen it wiggle and reinstall. If the tractor or starter still fails to work, they are at fault. If the lights work, watching the lights when the starter is engagd (in neutral)will tell you if the starter is getting voltage. The lights will dimm to 2/3 brightness if there is current flowing to the starter, but not doing anything. If the lights remain bright, there is a corroded connection, broken wire, or faulty ground, or open starter motor (Broken or needing brushes) Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
