Re: Farmall Belt Pulley
Posted by Lmack on September 30, 2011 at 18:22:17 from (72.145.203.180):
In Reply to: Farmall Belt Pulley posted by BillB52 on September 29, 2011 at 17:20:44:
The bolt pattern is the same and so is the gasket. Not all spline gears were the same. Some had a different number of teeth. If you are mounting a used gear box on a different tractor there will be issues with matching the gears. The drive gear has shims that can be removed or added to set the spacing from that direction but it is a machine shop job to remove the gear to add or remove shims. Additional shims are on the pulley shaft and these are easier to get to. Enjoy!
