Posted by Owen Aaland on September 30, 2011 at 19:36:49 from (216.47.32.147):
In Reply to: 1256 injection pump posted by DeltaRed on September 30, 2011 at 19:21:20:
You have the typical symptoms of a pump getting air in it. It doesn't happen often but you may have an air leak in the system but yet not leak fuel out. Most often it is a hose. It gets pulled in a little from the vacuum of the charge pump and then expands back again when not running so you have no fuel leaking. Any leak above the level of the fuel in the tank can also let in air but not leak fuel.
Be sure to check at the timing window to see if there are any "coffee grounds". That would indicate the weight retainer ring is breaking up and restricting the return.
This post was edited by Owen Aaland at 19:38:42 09/30/11.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
