Re: farmall m cuts out when under a load- push clutch in ...
Posted by wallylucius on October 01, 2011 at 06:30:20 from (71.193.72.33):
In Reply to: Re: farmall m cuts out when under a load- push clutch in ... posted by JRSutton on September 29, 2011 at 16:32:14:
i did change the plugs and new wires also- i will have to change the condenser i guess and will drain out the carb and see if that works- also clean the scren on the carb if its got one and do the gas cap thing also- will see how its going- as im going to the cabin today- will let you all know how it goes
