Posted by pete 23 on October 01, 2011 at 11:15:22 from (74.32.234.149):
In Reply to: 856 PTO posted by Dodge2500 on September 30, 2011 at 20:43:32:
If you are talking about that little bitty pin that either shears off or falls out , you assemble it and then insert valve from the bottom. Probably better look at a break down to get all parts back where they belong as there are shims, spacers, little washer etc that go in from the top and need to be correctly installed. Only valve and plug from bottom, no need to go inside pto.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
