Posted by 36F30 on October 01, 2011 at 15:28:30 from (71.38.169.170):
In Reply to: F 12 valve timing posted by Craig45 on October 01, 2011 at 14:22:49:
Page 33 of my 1935 F12 instruction book says to set valve clearance at .016. It says nothing about them being set hot.
To check the valve timing first set the valve clearance as above and then with number one piston at TDC rotate the engine just to the point all play is taken up in the intake valve lever. Then look on the flywheel there is an I/O mark on it and it should be within 3/8" either way of the timing mark on the bellhousing. If its not, your out of time and I would look at the front crank gear, I have found a couple that ate up the keyway and were loose enough to affect the valve timing.
This post was edited by 36F30 at 15:30:11 10/01/11.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
