The bull pinion retainer, on SC &SH, is easy to remove without getting into the trans. It's the regular H and I suspect the regular C that you have to get into the trans. I have done an H,SH,&SC.
The "inside friction plate"/brake pad has no retainer just pry it off. Clean the splines thoroughly. The brake pad discs need to be able to move freely on those splines.
The "brake interior housing" is called the "bull pinion retainer" These may need to be machined if they are too grooved.
To remove the bull pinion retainer I use 3 small chisels in 3 different locations around the retainer, look for the indents to put chisels in. Tap them in a little at a time till it comes out. If you tap in too far you risk breaking it and or binding. It's a 5 minute job getting it off.
No shaft to drop.
Once you have the retainer off the bull pinion gear can be easily removed, just pulls out, to clean the splines. I tape up gear,bearing,and seal surface in a plastic bag and blast the splines in the blast cabinet.
Search the archives as there is a lot of good info.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
