Re: H Coolant Leak
Posted by David G on October 01, 2011 at 18:23:03 from (205.215.206.18):
In Reply to: H Coolant Leak posted by George Rausch on October 01, 2011 at 18:04:49:
The panel is probably rusted through. I would not run it with a leaking panel. I just replaced mine this spring.
Here are the things I learned.
The block was half filled up with rust. I power washed the block out when I had the plate off, it is an easy way to flush it. Take the wand from a power washer and wash down inside the passages.
The replacement covers are thin and need RTV to seal them. I ended up making the gasket from RTV and it sealed. The bolts go into the water jacket, put some RTV on them also.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
