Assumes it is a Gasoline engine. Poor battery cables, weak battery, or poor ignition switch are probable cause items. Battery voltage when cranking must be 10.8 volts or more. If not the coil will not get enough voltage to operate. Voltage drop happens when the wires are too small OOgauge needed. battery needs to be able to crank it with lively turnover, Not RRRrrrRRR. A dragging starter motor will also make this happen. The fact that it runs when pulled, indicates it is getting sufficient fuel. (assumes choke is working and being used) Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
