Re: Re: Re: 2 Speed M Trans
Posted by Brian Banks on August 22, 2000 at 15:50:32 from (207.177.89.210):
In Reply to: Re: Re: 2 Speed M Trans posted by S-E Michigan Part Timer on August 21, 2000 at 16:32:13:
sounds like a overdrive to me. If the lever is in front of the clutch. My dad also has one. It only works in gears 1-4 and reverse. Dont use it if you are using the hydraulics because it can speed up the pump and burn it up.
Post A Followup
: Re: Re: Re: Re: 2 Speed M Trans
