Re: 650 pull starts on gas only
Posted by caseman-d on October 01, 2011 at 20:36:27 from (67.142.174.22):
In Reply to: 650 pull starts on gas only posted by red bearing on October 01, 2011 at 18:12:56:
I have a 650 that I couldn't get started on gas. Most times the diesel engine needs warmed up before it will start while pulling it. I tried pulling it and starting it on the diesel side, no such luck. Then switched it to gas and still no luck, thought it may have been electrical problem. Switched back to diesel, while being pulled I kept moving the throttle. In a certain spot it would fire. Once I found the right spot it finally started on diesel. Seems like something in the switch over was stuck. I drove it around till the steering would only work in one direction. Once I got it back to the shop I thought what the heck and went to shut it off on gas, wasn't expecting it to run but it purred like a kitten on gas. Been starting like a charm since.
caseman-d
