If I understand correct, with the sparkplugs removed the engine still has a tight spot I wonder if the engine run good after started? If so the valves and valve train is probably okay and maybe the pistons. May want to check the main and rod bearings for wear. Wear pattern should show if a crankshaft or rod is bent or block bearing bore off. Also maybe a bent cam or other shaft bent that bind the front timming gears. Also do you mean the timming was one inch from mark and you changed it?
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
