Re: farmall m cuts out when under a load- push clutch in ...
Posted by Mike1972chev on October 02, 2011 at 06:41:36 from (99.75.48.212):
In Reply to: Re: farmall m cuts out when under a load- push clutch in ... posted by wallylucius on October 01, 2011 at 21:18:40:
They are about 5 bucks.
I didnt know if the tractor was a 12 volt system or not?
WARNING: they come in different levels of resistance.We need to know if your coil is 6 or a 12 volt coil? If you DO NOT know which coil you have,take an ohm meter,touch it to the + and - on the coil with NO wires hooked to it,and hold it them there for a few seconds.
If the reading is around 1.2 ohms it would be considerd a 6 volt.If it is about 1.5 ohmns,it would be considered a 12 volt.A good resistor is NAPA part # ICR13 is aproximately 1.8 ohms and should work out to reduce either of those coils to the reccomended 2.7 to 3.3 TOTAL ohm requirement/resistance to keep from burning up your new points.(this comes from the discussion forum on here"recomendations for 12 volt conversion")
