Re: 650 pull starts on gas only
Posted by El Toro on October 02, 2011 at 07:10:21 from (108.3.225.100):
In Reply to: Re: 650 pull starts on gas only posted by red bearing on October 02, 2011 at 05:01:27:
That's probably a good idea is to replace the battery cables. Old welding cable makes good battery cables using soldered lugs. Clean all those areas where your battery cables connect including where your battery is grounded. Hal
