Re: 39 M stiff area in motor when cranking
Posted by Janicholson on October 02, 2011 at 10:32:38 from (67.72.98.45):
In Reply to: 39 M stiff area in motor when cranking posted by BUCK CLAYTON on October 01, 2011 at 20:45:52:
If it actually runs if pull started and seems fine when running, It is a mystery. The only thing I can think of that might apply to the given content is dramatic carbon buildup in one cylinder such that its compression ratio is near 10:1. A bore sight tool (for looking into gun barrels) used in the cylinder after dark or in a dark building would show that if it was the case.
A broken ring in one cylinder scoring the cylinder, would be very short lived, make noise, and smoke like a fogger.
Broken pistons would be similar in quick death.
Is the tight spot once every crank revolution, or every other revolution (actual 360 on front pulley).
This tells us if it is a mechanical issue, or a compression issue. Jim
