Use a test light. they are ~2.50$ They look like a small screw driver and have a wire attached. The power should be found at the wire supplying the fuse, both ends of the fuse, the bracket of the fuse holder to the switch, the wire connecting to the lights, and at each light. Poor connections at any point will thus be evident. The dimming resistor on the IH light switch must be good to have Dim lights. If it is not good, there will be no voltage for the test light on D position. If the tractor is equipped with light bulbs or sealed beams from other applications that draw more watts than the original, the D position will burn out the wire resistor in a flash. the switch is not good for much more than the original lights, unless run through a power relay to avoid over loading the switch contacts. Keep us in the loop. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
