Re: Brake job on SM
Posted by Janicholson on October 02, 2011 at 10:55:03 from (67.72.98.45):
In Reply to: Re: Brake job on SM posted by lblock on October 02, 2011 at 06:59:51:
Make sure that the distance from the inside surface
of the housing to the transmission friction plate
(total distance that the 2 disks and expander fit
into) is .040 to .060 larger than the stacked
height of the disks and expander when collapsed.
This leaves running clearance and keeps the geometry
of the linkages correct for max breaking, and good
release. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
