I have a C that was stuck when I got it. After I broke it loose it would stick real hard in one area. I tore it all down and found that the rings were all froze up in the piston and the clinder wall had the usual taper after years of use, so when the piston got near the bottom the rings wouldn"t compress and I could barely turn it over. Maybe on yours one or two of the rings are stuck with corrosion or even some carbon(I know unlikely on a propane tractor). Just a thought.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
