The jumping tractor (SM would burn up its wiring only if it was accidently hooked up backwards. THe alternator is self limiting, and the battery will only put out so much. If it has not run for a year or more it could have stuck rings. If you do a compression check, and it seems to be in the 120 to 130 area on all cylinders, I suspect stuck rings. Putting a two tablespoon shot of ATF into each cylinder can't hurt. Best of luck, Jim
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
