The loom material of choice is plastic split corrugated tubing. It slips on over the existing wires, One way to do this is to label all wire ends with a wire labeling tool (number each terminal end, and number each terminal) take photos as you remove the harness (not to tough,). Then place it on a board and staple the ends down. Place a push pin where every corner or branch is sprouting. Split what ever remains of the cotton loom, and remove it. Colors will be evident, as will length of each wire. Use quality NAPA or professional terminal ends, and solder them then shrink tube each. When done, use the split tubing to cover them, and tape the connections in the tubing with electrical tape. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
