Re: Super C engine block numbers
Posted by 400Dtractorman on October 02, 2011 at 21:55:48 from (24.112.136.165):
In Reply to: Re: Super C engine block numbers posted by GRAPE-DRANK on October 02, 2011 at 11:43:26:
Grape Drank, the block #'s starting with 35 were used on SC and 200. The 230 started with 36. Its not the same as you can't put the use the 3 1/4 kit in the 230. I know because I was told buy a tractor puller and checked with a local IH dealer. The block is smaller at the bottom on the 230 for some reason. To use the 3 1/4 kit you have to bore the block and fill and bore the bottom for the o'ring on the 230 block.
