Re: 2 Speed M Trans
Posted by Roger on August 22, 2000 at 19:50:05 from (209.224.36.36):
In Reply to: 2 Speed M Trans posted by S-E Michigan Part Timer on August 21, 2000 at 15:58:19:
I just rebuilt my high/low transmission adapter on an MD. The problem is that it was made by an aftermarket company and parts are very hard to find. I ended up going to a bearing company and matching the bearings as my main pilot bearing was bad. I never thought of the problem with the hydraulic pump speed. That must be the reason the guy who owned the MD before me had another aftermarket modification that allowed you to uncouple the hydraulic pump with the pull of a lever. Roger
Post A Followup
: Re: Re: 2 Speed M Trans
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
