Re: noise in 454 gas engine
Posted by Jimb2 on October 03, 2011 at 13:40:09 from (174.115.9.174):
In Reply to: noise in 454 gas engine posted by corbin wood on October 02, 2011 at 18:57:24:
Hi, I had a GM 350 that would do that and a mechanic had me convinced it was a worn timing slapping against the cover and he was going to have to pull rad and everything off the front of engine to replace. I am lucky he didn't have time to work on it that week. I took it home and used the old broom stick method and found it was coming from the fuel pump. Remove fuel pump and the return spring was broken. I guess the fuel pump lever was not following the cam and at certain speeds was making the knocking noise.
JimB
