Pull the plug wire on the cylinder that is closest to the noise. if the noise changes substantially, it is likely a wrist pin that is loose. The rod would need a new bushing pressed in, and fit to the old, or new wrist pin. The fit is .0005" max. if tighter but still will move by easy hand movement on the pin it is OK. Loose timing gears from the front pulley being improperly seated is another possibility if the noise does not change with the plug wire off. Loose cam gear is actually modestly common. Valve adjustment wrong (loose) is possible, as is a rocker arm moving sideways on its shaft. A worn valve guide also makes the same noise, Usuallt so worn that it can be moved sideways with the spring on it. Best of luck. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
