Re: I.H. Side Hill Hitch. Did I get a good deal???
Posted by Keith Williams on October 04, 2011 at 07:01:16 from (208.81.151.130):
In Reply to: I.H. Side Hill Hitch. Did I get a good deal??? posted by Mike1972chev on October 04, 2011 at 05:04:54:
Mike,
"Hill Side Hitch". It really does help when you switch from throwing the furrow up hill to throwing it down.
Been so long ago I forgot about using it on the contour strips. You would use the hitch to adjust as you went around a inside curve or around an outside bend. You can adjust some by changing where your wheel is in the furrow, but on my strips, I would run out before I got all I needed.
The ford plow had an adjustment bult into the plow but you had to have it raised up to reach the handle. I thought many times about putting a hydraulic cyl on that one to adjust on the fly.
Keith
