Re: 656 still not starting and getting frustrated
Posted by super88 on October 04, 2011 at 11:05:55 from (207.109.6.218):
In Reply to: 656 still not starting and getting frustrated posted by don656 on October 04, 2011 at 10:20:42:
Your missing something simple here. It's not that complicated of a system. You should have 12 volts from yor key switch to the positive side of the coil. You will only have current from the coil to the dist when the points are closed. Either your points are out of adjustment or your condensor is either bad or the wire is grounding out on the side of the case. Check your spring on the points and your condensor connection.
Today's Featured Article - A Lifetime of Farm Machinery - by Joe Michaels. I am a mechanical engineer by profession, specializing in powerplant work. I worked as a machinist and engine erector, with time spent overseas. I have always had a love for machinery, and an appreciation for farming and farm machinery. I was born and raised in Brooklyn, New York. Not a place one would associate with farms or farm machinery. I credit my parents for instilling a lot of good values, a respect for learning, a knowledge of various skills and a little knowledge of farming in me, amo ... [Read Article]
