Posted by pete 23 on October 04, 2011 at 11:11:11 from (74.32.234.149):
In Reply to: super c with hicups posted by nc super c 1 on October 03, 2011 at 20:35:57:
You need to determine if leak is in cyl or check valve. With hitch raised, load on it, engine shut off, see if the hose on rod end of cyl(which is not supporting the load) has pressure in it, if it does your cyl is leaking. May require unhooking hoses to determine. If oil comes out of that hose, cyl leak. If oil actually lowers in hose, check valve is leaking. Just be sure you check correct hose as of course the one to lower end of cyl will have pressure.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
