Re: 300 runs bad under a load
Posted by rhtx55 on October 04, 2011 at 17:15:47 from (207.119.44.67):
In Reply to: 300 runs bad under a load posted by EvanMellott on October 04, 2011 at 05:18:00:
Turn the main jet on the carb GENTLY !!! until it is completely closed,
Back it out 5-1/2 turns & try it under load then. If it blows black smoke out of the muffler under load, turn this screw in 1/2 turn at a time, until it doesn't blow black smoke, that will be the "hard pull" setting.
If it will not blow any black smoke, at 5-1/2 turns out you have either a fuel supply problem as discussed above or a clogged main jet in the carb.
When doing light work, turn it in a turn & 1/2, or 3 to 4 turns out from closed or until it stops smoking under accelleration from half to full throttle, this should be close to the "light load" setting.
