Posted by charles todd on October 04, 2011 at 18:40:42 from (205.242.95.136):
In Reply to: Rusted Rims posted by John V. on October 04, 2011 at 15:56:19:
I have done this repair recently to a front tractor rim. I used a carbide burr to open the hole a little and welded in a thick SAE washer to fit. I then filled in the center hole of the washer and ground the area smooth on both sides.
Next I moved 180 degrees out and drilled a new hole with a uni-bit and put a valve stem in. Of course after sand blasting, priming, and painting the rim. :D
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
