Re: Turbo boost pressure on DT 361 - 1206 motor
Posted by tractorsam on October 05, 2011 at 17:49:05 from (173.224.244.121):
In Reply to: Turbo boost pressure on DT 361 - 1206 motor posted by Larry B 1486 on October 05, 2011 at 12:50:47:
Sorry I can't help with most of your questions but I can say that with only 2-1/2 psi boost you're not going to see very much power. I would have expected to see a higher number. When she's pulling hard does she smoke? You didn't mention any smoke and I would expect that if the turbo was too small it would cause it to smoke quite a bit. To my way of thinking the turbo isn't going to work right if it isn't fed enough fuel. Sam
