Posted by rustyfarmall on October 06, 2011 at 07:00:08 from (216.248.71.224):
In Reply to: farmall H- 1940's posted by 53 super H on October 06, 2011 at 06:37:23:
If you're talking about that fuzzy little piece of felt with the hole in the middle, that is NOT a packing. It is intended to be a dust seal for the choke shaft, but it ain't much good for that either. The kits I sell include the packing, and it is identical to what Case-IH sells. I have compared them side by side.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
