Posted by rustyfarmall on October 06, 2011 at 14:27:46 from (216.248.71.224):
In Reply to: W4 Fuel Problem posted by BLACK on October 06, 2011 at 14:04:34:
My guess is that you didn't go far enough when you took the carb apart the second time. The float might be sticking on the hinge pin, or the needle valve might be stuck in the seat. Unless you thoroughly cleaned out the gas tank when you first got it running, there is still some old, varnished gasoline in there, and that is what is causing your fuel problems. Eventually, that old gas will get diluted enough that it will no longer cause problems, or you can have the tank cleaned out and eliminate the problem right away.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
