Mark the notch on the damper pulley with some chalk. Remove the sparkplug near the radiator and hold your thumb over the plug hole while a helper hand cranks the engine until you feel pressure against your thumb. Have the helper to keep slowly cranking the engine as you watch for timing mark with the chalk until it's aligned with the pointer.
Then see where your rotor is pointing. It should be at the No1 plug tower which is about 2 o'clock. If it's off you need to pull the distributor and rotate the rotor so it's at 2 o'clock and reinstall it. Hal
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
