Re: 1066 stops
Posted by Owen Aaland on October 06, 2011 at 22:48:08 from (216.47.32.147):
In Reply to: 1066 stops posted by 1968 403 on October 06, 2011 at 19:43:48:
One possibility is a worn out MCV pump or a leak in the TA circuit and a TA with the low side out. Applying the brakes take 1 GPM flow from the TA circuit. That may be enough to cause the clutch apply pressure in the TA to drop off and if the mechanical clutch in the low side of the TA is worn out the tractor will stop as the hydraulic clutch in the TA loses pressure and slips.
