Posted by Owen Aaland on October 07, 2011 at 05:41:16 from (216.47.34.27):
In Reply to: 1066 stops posted by foreverIH on October 06, 2011 at 19:43:48:
Poor steering at idle is usually the first indication of MCV pump problems. If you don't have a TA then the MCV pump is not part of the problem. Without a TA everything is just mechanical drive.
Does the tractor have a differential lock? Does it pull OK when you are not using the brakes? Does the right brake also cause the tractor to stop?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
