Re: 1066 stops
Posted by mkirsch on October 07, 2011 at 05:51:32 from (64.80.110.75):
In Reply to: 1066 stops posted by 1968 403 on October 06, 2011 at 19:43:48:
Does the tractor REALLY not have a TA, or did someone just remove the lever?
Because, the behavior you describe is impossible without a TA unless you have some serious differential problems.
On true TA-delete tractors, there is a solid shaft running through the TA housing. Nothing hydraulic.
If your tractor is a true TA-delete, then your differential is wrecked.
