Re: Farmall A wiring - charging options
Posted by old on October 07, 2011 at 10:25:57 from (209.86.226.32):
In Reply to: Farmall A wiring - charging options posted by swedishfish on October 07, 2011 at 08:34:09:
6 volt or 12 volt switch does not matter they are rated in amps not volts. As for the generator system it can be wired to put out 12 volts but just putting on a 12 volt V.R will not do it. But since you want to keep it looking like it did you could always rig up a PTO drive alternator system to power your lights so you would have a 6 volt system for the tractor and a extra 12 volt system for the lights that would be run off the PTO
