Help with M Bearing Removal
Posted by Loren in Iowa on October 07, 2011 at 17:28:55 from (207.177.2.187):
Got the M split, and the bearing on the hydraulic pump drive shaft seems real loose. Pulled the seal housing, and need some advice on how to remove the bearing from out of the front of the transmission. Does it pull right out, or is there a trick? Would like to replace it.
