Re: Farmall A wiring - charging options
Posted by gene bender on October 07, 2011 at 19:09:11 from (67.55.227.142):
In Reply to: Farmall A wiring - charging options posted by swedishfish on October 07, 2011 at 08:34:09:
Your generator is the original but it never had a regulator it came with a cut-out you need to get the tractor charging system back to original then get a 12v battery for your lites on whatever you want to pu that way the tractor will be good to go and not have any charging problems. You can use whatever volts on the wagon and with its seperate battery you wont have any problems.ll
