Re: 656 weak pto pressure
Posted by Janicholson on October 07, 2011 at 21:43:58 from (67.72.98.45):
In Reply to: 656 weak pto pressure posted by Yellott Canby on October 07, 2011 at 20:11:14:
Use a shim on the stop on the over center control. Make sure it goes over center and is not in danger of "falling" out of engagement. A flipper and notch could be installed with a rod to lift it when disengaging the PTO. See the lever on a 400 Farmall. I think it will work. The Vet said bend the rod some, maybe this allows it to pull after over center (just thinking out loud) Jim
