Re: 656 weak pto pressure
Posted by LarryT on October 07, 2011 at 21:49:54 from (174.56.65.35):
In Reply to: 656 weak pto pressure posted by Yellott Canby on October 07, 2011 at 20:11:14:
That is adjustable. If you will look at the parts breakdown on that unit (I am attaching the url to the web page below) you will get an idea of how it goes together and where you can make the adjustments. The spring tension may be off a little but that's easily adjusted. Hope that this will help. LarryT
