Re: 656 weak pto pressure
Posted by The tractor vet on October 08, 2011 at 06:08:20 from (76.212.225.127):
In Reply to: 656 weak pto pressure posted by Yellott Canby on October 07, 2011 at 20:11:14:
IF ya got the valve stem SCREWED INTO THEW NUT AS FAR AS IT WILL GO THEN YA NEED TO RAISE THE LINKAGE UP ON THE MOUNTING BOLT HOLES .
