Re: MD starting carb questions
Posted by pete 23 on October 08, 2011 at 17:51:25 from (74.32.234.149):
In Reply to: MD starting carb questions posted by jfrankhash on October 08, 2011 at 11:32:47:
The connecting of those two ports with the copper line was an idea some one came up with to make them start better. The tube used was actually the original drip tube. Some other changes were made internally also to go along with this set up. I believe we drilled a hole in the well tube. I did a few of them about 50 years ago when an older mechanic in neighboring dealer showed me how he did it. It seemed to make them start better but they were extremely sensitive to choke position. I quit doing it later on. The idea of the drip tube is to drain flooded gasoline off to ground.
