look what followed me home
Posted by lkm on October 08, 2011 at 19:09:53 from (66.119.109.234):
After lookiing for several years finally found this (hay press) baler very close to home. Its a IH with serial # 5056P Its in suprisingly good mechanical condition, and after cleanng up restoring wood parts and painting, plan to use it as demonstration at various tractor shows in the area. Does anyone know the years that this type baler was made? I also would like to see a diagram of the wood blocks that are put between the bales to slip the wire or twine through to tie the bales. I would like to make them as origional as possible.
