Posted by Wardner on October 09, 2011 at 06:34:17 from (4.154.232.205):
In Reply to: IH 300 crank? posted by mike paulson on October 09, 2011 at 01:08:07:
Lots of unknowables can be figured out. For instance, look at the fan and visualize the direction it must turn to pull air. Or look at the hand-cranking sleeve that engages the end of the crankshaft. Or just bump the starter. Or remove the starter and see what way it turns. Or put the tractor in fifth gear and rock it with the ignition off. Look at the fan while doing that.
Anyway 99%+ motors turn in the same direction. Exceptions would be some marine engines and special industrial engines.
Yes, some tractors have pusher fans but you would know that if you ever walked in front of a non-moving running tractor that is set up that way.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
