Re: IHC B 250
Posted by Jimb2 on October 09, 2011 at 07:56:29 from (174.115.9.174):
In Reply to: IHC B 250 posted by bcdave on October 08, 2011 at 22:05:08:
Hi, good tough reliable tractor. There were several common parts with later models, B275,B414,434,444,384.
Most common PTO problem is there is a pin on the PTO engagement shaft that pushes a collar to engage to PTO. The pin shears off and PTO is either ON or OFF.
The pin can be replaced by removing the PTO engagement lever and shaft.
I believe the only really difficult repair item is the inline fuel injection pump.
Maybe MJ in UK or someone with more up to date parts experience can add more.
JimB
