Re: td-6
Posted by Janicholson on October 09, 2011 at 15:11:52 from (67.72.98.46):
In Reply to: td-6 posted by sven on October 09, 2011 at 08:37:49:
A tilting flatbed trailer with enough capacity is probably best. If it is positioned such that it can be aligned so its drawbar (rearend) is situated to go on first, it can be winched on directly, dragging the blade.
If not, lifting the blade and chaining it up is going to take a couple of 5 ton or better hydraulic jacks and blocking. Once up, it should be able to be moved in Neutral and loaded by winching. Jim
